Last activity: 28 Jan 2016 11:50 EST
Connecting to external SQL database
We are connecting to an external SQL database and seeing weird behavior with the SQL driver.
PRPC is running on oracle database and so for connecting to SQL additional jar file was added. We are using Pega cloud servers.
After few hours of non usage of this external connection somehow the test connection is failing. Usually observed after overnight:
Testing Database connection gives failure.
Then I go and check in SMA for the java class name “com.microsoft.sqlserver.jdbc.SQLServerDriver”, expecting that the class should not be there as the test connection is not working.
Here it finds the class:
And then I again try to test connection to make sure I still see the Test Connection error. But, this time it gets connected successfully.
Not sure how just searching for the class name fixes it up.
Has anyone seen this issue? Any suggestions about what may be causing this
We are on 7.1.8
