Issues in managing Pega and IAC thru WebSeal Standard junctions
We are trying to achieve SSO thru IBM WebSeal, we could able to do so for Pega application using Transparent Junctions. For example, if our external URL is www.abc.com, then we could able to achieve SSO by routing traffic to F5 LB VIP (for example Proprietary information hidden which finally became Proprietary information hidden/prweb/*. But we have requirement for IAC implementation along with Pega application on same host/domain name, but to achieve this, we may not be able to by using transparent junctions on same webseal instance, hence we may need standard junctions. For example, www.abc.com for Pega application that will go to F5 LB VIP like Proprietary information hidden/prweb/* and www.abc.com/iac that will also go to another F5 LB VIP like Proprietary information hidden/prweb/*, but we are failing do so as we are having to some AJAX issues. Can you please guide us if we can use standard junctions for this scenario and how?
Also, we are thinking about deploying prweb.ear file with different context path, such as for Pega application, it will be deployed as default prweb context and for IAC we want to deploy prweb as IAC as context path. WIll this work?
Please let me know if you need any further details.
