how to attach excel file to mail?
Hi everyone.
I need to do the following action:
1. We have page list with data and generated Excel file with these data
3. Need to send email with this Excel File.
We are doing it out of WO. How to attach Excel file to mail?
I see many topics about the same issue on PDN, but still can't find any solution for it.
Thanks in advance for your help
Likes (1)
Hi all, going to provide a simple case of my task.
Pre-condition:
- Page List with the data below. TempPage(code-pega-list). TempPage.pxResults() - q-w-e-r-t-y class
TempPage.pxResults(1).Test1 = "X1";
TempPage.pxResults(2).Test1 ="X2";
TempPage.pxResults(3).Test1 ="X3".
My solution:
1. To create a new activity AttachExcelToMail.
2 To create HTML rule GenerateExcelStructure with the content below:
<html>
<body>
<table border="1">
<tr>
<th>Test1</th>
</tr>
<pega:forEach name="TempPage.pxResults">
<pega:withEmbedded name="$THIS">
<tr>
String Test1= tools.getStepPage().getString("Test1");
tools.appendString("<td wrap>" + Test1+ "</td>");
</tr>
</pega:withEmbedded>
</pega:forEach>
</table>
</body>
</html>
Pre-condition:
My solution:
<html>
<body>
<table border="1">
<tr>
<th>Test1</th>
</tr>
<tr>
</tr>
</pega:forEach>
</table>
</body>
</html>
Activity AttachExcelToMail.
1. Property-set-HTLM.
param.pyFileData = "GenerateExcelStructure"
2. Java
String strFileData = getParameterValue("pyFileData");//getPrimaryPage().getValue("pySrc"); Page objHeadersPage = getProperty("pxRequestor.pyHTTPResponseHeaders").getAsPage(); if (objHeadersPage.isBound()) { objHeadersPage.setValue("contentType" ,"application/vnd.ms-excel"); sendData("", strFileData); } else { sendData("","Error. Can't get \"pxRequestor.pyHTTPResponseHeaders\" page"); }
3. Page-New
AttachmentLinksOpened page (code-pega-list)
4. Property-Set
- AttachmentLinksOpened.pxResults(<APPEND>).pxObjClass = 'Data-WorkAttach-File'
- AttachmentLinksOpened.pxResults(<LAST>).pyAttachStream = PegaFunction Base64Encode(param.strFileData).
5. Page-New AttachmentPage ( Data-EmailAttachments)
6. Property-Set
- AttachmentPage.pyAttachment(<APPEND>).pyDecode == True
- AttachmentPage.pyAttachment(<APPEND>).pyName == "ExportReport.xls"
- AttachmentPage.pyAttachment(<APPEND>).pyReference == AttachmentLinksOpened.pxResults(1).pyAttachStream
- AttachmentPage.pyAttachment(<APPEND>).pyRemoveXML == False
If you have any comments please let me know.
Hope this article help you.
Thanks.
Hi
can you please elaborate on the point "We are doing it out of WO "
If it is something like you want to send email out of your workobject with an attachment then you can refer this help article : https://community.pega.com/sites/default/files/help_v718/procomhelpmain.htm
Santanu, thanks for the help.
One more question.
I have the following content of my Excel file.
<html>
<body>
<table border="1">
<tr>
<th>test1</th>
</tr>
<tr>
<td wrap>value1</td><td wrap>value1</td><td wrap>value1</td><td wrap>value1</td>
</tr>
</table>
</body>
</html>
How can i put this value in pyReference property?
Thanks in advance.
Hi all,
Half of the issue is solved.
1) I created AttachmentLinksOpened page (code-pega-list).
2) Set AttachmentLinksOpened.pxResults(<APPEND>).pxObjClass = 'Data-WorkAttach-File' and AttachmentLinksOpened.pxResults(<LAST>).pyAttachStream = "content of my Excel file".
3) Set pyReference as AttachmentLinksOpened.pxResults(1).pyAttachStream
Now I can send email with Excel file, but Excel file has incorrect data (some strange characters)
Any ideas?
Thanks in advance for the help
Pre-condition:
My solution:
<html>
<body>
<table border="1">
<tr>
<th>Test1</th>
</tr>
<tr>
</tr>
</pega:forEach>
</table>
</body>
</html>
Pre-condition:
My solution:
<html>
<body>
<table border="1">
<tr>
<th>Test1</th>
</tr>
<tr>
</tr>
</pega:forEach>
</table>
</body>
</html>
2. Java
3. Page-New
4. Property-Set
6. Property-Set
Thanks.
Thanks for this post.
I did some changes to make it work for me.
AttachmentPage.pyAttachments(<APPEND>).pyDecode == True
- AttachmentPage.pyAttachments(<LAST>).pyName == "ExportReport.xls"
- AttachmentPage.pyAttachments(<LAST>).pyReference == "AttachmentLinksOpened.pxResults(1).pyAttachStream" {Reference in double quotes}
- AttachmentPage.pyAttachments(<LAST>).pyRemoveXML == False
No need to call Java step. Directly put pyFileData as reference
AttachmentLinksOpened.pxResults(<LAST>).pyAttachStream = PegaFunction Base64Encode(param.pyFileData).
!Thanks
Ajay
What would be next step after populating AttachmentPage.pyAttachements?
I called SendEmailWithAttachments after setting pyreference and supplied the required parameters. I did get the email but without attachment.
Can you please elaborate what steps did you add after it?
Hi Arjun Shaw
After setting values AttachmentPage
I put a Property-Set
param.AttachmentPage = "AttachmentPage"
And just calling 'SendEmailWithAttachments' worked for me.
Ajay
Hi Ajay,
It worked for me when I called the OOTB function SendEmail with the parameter as AttachmentPage.
Calling OOTB Activity SendEmailWithAttachments is not working in this case.
Thanks for your input.
Arjun Kumar Shaw
