- Contact a Moderator
Back to top
Back to top
Related content:
CLR enable for SQL Server
Is it possible to install pega without UDF's : Without clr enabled setting
Request for statement from Pega that PRPC uses CLR feature of Microsoft SQL server
UnExposed Properties
Can we able to run this report without CLR enaled on the DB server
Using windows authentication for SQL Server in properties file
Datasource Properties for SQL Server
Unexposed properties cannot be mapped to properties mapped to external tables
Unexposed properties - CommPreferenceByMail
