Lanit
RU
Last activity: 22 Dec 2015 9:29 EST
Parent flow doesn't resume after subflow ends
When subflow reachs end shape process stops.
I use set ticket to get back to the parent flow, but it's a bad solution.
Does anybody know what's the reason if this strange behavior?
Nikolay,
Hello. It should not be doing that. I would look at the pxFlow page. You should see a page for the subflow (before you get to the end shape) and the parent flow. It should essentially be the call stack. There should be references to the parent in the subflow. If they aren't there, I'd want to know how you are calling the subflow.
Mike
Lanit
RU
Hi Mike! Thanks for reply!
I took a look at pxFlow(subflow_name) page before end of the subflow. It contains propserties related to parent flow (pyParentFlowPath, pyIssuedFromFlow...). Page pxFlow(parentflow_name) is also presents at the pyWorkPage. I'm calling my subflow from parent flow just using SubProcess shape.
Lanit
RU
Does anybody else have any ideas?
Hi Nikolay,
Does Tracing with the Flow event type enabled provide any clues?
Carissa
Lanit
RU
Hi Carissa,
Unfortuntely, trasing provides nothing. I've opened a SR and seems like it's a core Pega issue. A hot fix was provided.
What version are you using? Also can you post screenshots of your flows?
Looks like an issue with the product. Someone else posted this issue in PDN on 12/17/2014 (https://pdn.pega.com/forums/case-management-and-process/parent-flow-not-getting-resumed-when-sub-flow-ends). There is no concrete response on this pdn post as well. Did you log an SR with Pega GCS?
