Capgemini
Last activity: 4 Jan 2016 7:59 EST
Refresh Portal Harness issue
As a part of a larger use case, I am trying a couple of simple tests related to refreshing the harness for the pyCaseManager7 portal (OOTB portal - no customization done) and it doesn't seem to be working properly. Here are the details:
Pega version - 7.1.6
Approach 1:
1.I included a button / link in the pyPortalHeader section (which is included in the pyCaseManager7 harness for the pyCaseManager7 portal)
2.On click event of the button is configured as follows, however, when I click on the button, nothing happens (nothing shows in the tracer or fiddler)
Question - Is Refresh current harness not expected to work in this scenario?
Approach 2:
Approach 1:
Approach 2:
2.On click event of the button is configured as follows. Clicking on the button, reloads the entire portal, however, the wide panel disappears and after the refresh, if I click on any of the navigation options present in the left panel, it opens up the corresponding harness in the designer studio instead of the user portal.
Question -Has anyone encountered this before?
Is there an alternative approach to refreshing the whole portal?
Thanks in advance for any kind of suggestions
Regards
Sudit
