SedgwickCMS
Last activity: 14 Mar 2016 11:19 EDT
Any guidelines on maximum number of web services that any pega application can consume or host?
Any guidelines or suggestion on how maximum number of web services that any pega application can consume or host?
![](/themes/custom/pegacc_theme/images/user-icon.png)
Hi Raja Sekhar,
This depends on your the sizing of your app servers(JVM/Memory) and the average clipboard size of requestors in your application. There is no general guideline for this and this sizing should be determined primarily based on the number of peak requestors your application has to support and their average clipboard size.
There are few options to estimate it:
1. Using Clipboard-> If you know the response of the service then generate that response on a temporary page may be by running the service activity. Then go to clipboard -> Tools -> Analyze. This will give you the size of your page. Always try this with highest response size possible to safely estimate the required heap size.
2. Using SMA -> Access the SMA Application during your peak volume window and click the estimate size button. This is available in SMA-->Requestor Management, on the RHS Section at the top left( under all requestors).. Clicking this will add a column called Datasize in the list view with the size of memory occupied by your requestors.. Take an average of this.
Hope this helps.
Amit
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/6edb6beb-cf8e-431c-9679-ef67ce5f3aba.jpg?itok=hzTHfrBw)
There is no theoretical limit whatever as long as you have enough resources (RAM/CPU/Socket etc) and the most important guideline is to setup a performance environment and run through realistic scenario/loads. Monitor and tune.
SedgwickCMS
When Pega is consuming any SOAP services. If we want to test SOAP services from a performance(stress test) stand point, independent of Pega application to get the readings of SOAP services.
Any suggestions on testing the services independently from a performance standpoint so that I can evaluate with PAL/PLA alerts readings when calling from Pega application.
Yes. SOAPUI tool can be used to test your Services and get performance metrics for their response time etc.
SedgwickCMS
Hi Vipin,
From your experience, how close are these SoapUI performance metrics with Pega and also can you be more on the list of steps when we pull performance metrics from SoapUI?
Since SOAPUI is the actual client making SOAP requests to Pega application, the performance metrics captured in SOAPUI and in Pega ALERT log is the real deal. You should gradually increase the load to the point when the response time drastically reduces or the SOAP requests start to error out. SOAP UI documentation has details on how to set this up:
Hi Raja Sekhar,
Hope this helps.
Amit
