Coforge Limited
Last activity: 21 Dec 2016 4:50 EST
Hide Live UI
How to Hide Live UI in Pega 7 Admin Portal. We need to expose the admin portal to the users but dont want to expose the Live UI.
Please guide me ..
Thanks in advance..
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/acf9b3f6-41e7-4ef2-9e55-8da39714b54f.jpg?itok=JYQYUbWS)
Thank you Vinod, for updating us with the below resolution!
Perform the following steps to hide Live UI for end user portals:
1. Open Access Group and select pegaSysAdmin Role in list of roles.
2. Select @Base class in Access Class.
3. Make a pxUiInspector 5 to 0.
4. Check it in end user portal.
Lochan | Community Moderator | Pegasystems Inc.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689961000/e281d01d-7963-4fea-b544-6344c1f43953.jpg?itok=bMU4GDhu)
Hi Vinod,
Refer to this piece written back when we first started the PSC for help:
Live UI and UI Inspector Q&A: Pega Expert Blog
At the time it was written, it was in the context of 7.1.7/7.1.8. But assuming most of it still holds up, I believe the solution is as simple as removing the pxUIInspector privilege from your access roles.
Tagging Maxwell DeAngelis to confirm this is still true.
Thanks.
B.
Hi Vinod,
I guess by Admin portal you mean the Designer Studio. Here is a sample to disable (rather remove) the Live UI link from the portal:
1. After you login to the designer studio, turn on Live UI and place it on the Live UI link.
You will observe that the links are contained inside OOTB pzStudioFooter section.
2. Open the pzStudioFooter section.You can do a private edit or save it in your application ruleset.
You can then delete the link and save the rule.
Following the steps above, you will be able to hide/remove the link -
Capgemini
SE
This is a final rule. Can we really do that?
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-12/ef6e8c0e-f700-4d3b-be53-63e7045c2b58.jpg?itok=IFaNuXx5)
Areteans Technologies
This is based on the Role remove the access for the Live UI in ARO
Pega
remove the previlege pxUIInspector in the ARO
