Pega 7 import/export jar files
is there an automated way to import jar files into Pega 7 say ANT scripts or an API?
You can try using PegaUtils tool
I posted this on PDN as well but I want to ask the same question here. If you specify different db credentials - so import to prod - can you leverage an instance of pega as a 'build box'?
