Last activity: 15 Jun 2017 15:17 EDT
In Pega 7.2, how to mention target window in "Open URL in window"? height and width
hi
I need to open url with fixed height and width .
I tried to use Open URL in window with alternate domain ,there I am giving height and width but it did not work .
Virtusa
Hi Swathi,
Whether the new window opened with the target what you mentioned?
Is the size is only the problem?
Thanks.
new window is opening with given URL ,
the problem here it is not taking the height and width properties ,
how to solve this,i need to open in new window with given height and width.
Tata Consultancy Services
Hi swathi,
I tried the same and it is working fine.
Can you attach a Fiddler trace showing session for new window?
Capgemini
I have a similar issue, where the window size is not geting to be resized, even if I try to set the window size, can anyone help
Capgemini
Hi Swathi,
I have recently came to the realization that this issue can be solved by just passing any window name and then the height and thw width, please do not reference any parameters or property, just hard code any values, this will ultimately not show up in the pop up window, but the height and the width will be solved
CTS
can any body share the openurlbywindow script for 5.4 application..
I need to execute activity(connect soap to get few values) and frame url and put in one property. then open the url in new window or tab.
please help me..
