Display Modal Dialog if there are no errors.
We have requirement where on click of button - we need to validate if the mandatory fields are filled, if filled we need to show Modal dialog with msg & YES or no buttons. If the mandatory fields are not filled - we should not show the Modal dialog.
I referred the discussion & have tried this approach of including two buttons with visible condition. This is working fine but there is a issue in the date field.
First Save button
Second button with Local action
First Save button
If you update the date, & then remove the date without clicking outside of the cell, click directly on "Save" button. Am getting the second button action where I have configured Activity, Local action & my Local action is getting fired even when there are errors. Please advice a refresh has to happen when the user doesn't click outside the cell as well. If a refresh happens I will get my First button & the Local action will not be fired. Or is there any other better way other than this
