how to download Pega Web Mashup Pacakge
From where I can download Pega Web Mashup Package for my POC.
You can raise SR providing details of PRPC version you are using for POC
Hi Chetan,
Please let us know if you end up opening an SR so that we may track it through this thread!
Hi ,
Yesterday without getting / deploying prgetway.War . I got another option.
1. I have Generated Mesh up code from Case designer Action menu.
2. The File which I got that I saved as a HTML.
and then it tested its working as expected for me.
Can any one guide me how its working with out following the IAC deployments. (I have just inclded IAC ruleset in my application.)
Please advise if any risks in this.
Current Pega Version :7.1.8
Chetan
I tried this. How is this working..? In gateway URL it shows /prweb...means prweb has IAC code in it..?
As this is a POC, you should be aware that prgateway is being phased out in our future direction, instead, you should use any reverse proxy server, as described in this newly published article: https://community.pega.com/. In fact, starting 7.2.1 reverse proxy is not even required, so use 7.2.1 if you can for your POC.
