How to set system name in env with 2 PRPC sharing DB.
Hi there,
We have 2 PRPC nodes sharing the DB, and I need to rename system name for each node.
Approach A
High Level:
- Use OOTB System Setting landing to create a new System Name,
- Restart the PRPC node
- Apply the new Node ID generated from the System Name in the Search Index Host Node Settin
Now, I used to get errors during saving of a new name in the System Setting landing page, if this does not work I will try below
Approach B
High Level:
- Create the new System Name
- Create new Four Requestor Types
- Update DASS to use the new System Name
- Restart the node
- Apply the new Node ID generated from the System Name in the Search Index Host Node Setting
I noted that DASS PRCONFIG/IDENTIFICATION/SYSTEMNAME/DEFAUL for system name in DB is only one row in DB??? If I update the DASS to a new system name one node, and restart, would that confuse the other node, or should I set an entry in PRConfig 'Identification/SystemName' for each node. OR, the purpose PRCONFIG/IDENTIFICATION/SYSTEMNAME/DEFAUL is transcient (only referred to during startup for each node???
Regards
Seri
Hi there,
Approach A
High Level:
Approach B
High Level:
- Restart the node
Regards
Seri
1) Why do you want each node to have a different system name? The purpose of system name is to co-relate multiple nodes connected to the same DB as one cluster (AES / PDC rely on this)
2) You can use a prconfig setting instead of the Data-Admin-System-Settings to individually change the value for each node.
<env name="indentification/systemName" value="pega" />
If you do this, please make sure the remove the Data-Admin-System-Settings instance.
