Turkiye Finans Kat?l?m Bankas?
TR
Last activity: 15 Apr 2016 13:38 EDT
Filepath too long
hi
we are using 7.1.7 Pega version.
when I uploading a file I am getting below error.
| Status | fail |
| Message | java.lang.StringIndexOutOfBoundsException: String index out of range: 203 |
| Operator ID | Unauthenticated or not available |
| Requestor ID | No ID available |
| Timestamp | Fri Apr 15 10:44:41 EEST 2016 |
| Engine Version | PegaRULES Web Tier 7.10 ML7 (coreAssemblyCached_717_644) |
my file path is V:\BEDDİ BEY VE MMMXX BEY'İN ÅUBE YETKİSİNDEKİ KRDİLERE AİT FARKLILIKLAR HK UYGUNLUK
I think problem is that file path is too long and contains Turkish character.
when I used short path is working well.
how can I solve this problem
JP
I guess the culprit is the SPACE in the file name.
TR
No space is not problem.
I used another file path that includes space it is work.
JP
Are there any stack traces in the log files, which may shed more light on the issue?
TR
my stack traces
at java.lang.String.substring(String.java:1907)
at com.pega.pegarules.web.fileupload.MultipartParser.extractDispositionInfo(MultipartParser.java:385)
at com.pega.pegarules.web.fileupload.MultipartParser.readNextPart(MultipartParser.java:275)
at com.pega.pegarules.web.fileupload.MultipartRequest.<init>(MultipartRequest.java:178)
at com.pega.pegarules.web.impl.HttpUtilities.fileUpload(HttpUtilities.java:450)
at com.pega.pegarules.web.impl.HttpUtilities.extractRequest(HttpUtilities.java:316)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:434)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:290)
at sun.reflect.GeneratedMethodAccessor164.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
my stack traces
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:118)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:751)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:844)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:346)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:243)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3432)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3402)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2285)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2201)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2179)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1572)
at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:255)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:311)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:263)
JP
I guess the issue is worth to raise an SR.
TR
maybe problem is that pxTextUploadEncoding is UTF
Please let us know here if you end up raising an SR.
Thanks!
Lochan
TR
I don't understand.
What is SR ?
SR is a Support Request that you raise with Pega Global Customer Support (https://collaborate.pega.com/question/how-raise-sr-my-support-portal-how-question) for detailed investigation of a product defect.
Please check with your Account Executive for more details!
TR
hım Ok.
We don't create SR for this issue now
Hi Harun,
I came across a similar issue in one of the PDN articles. Please go through it to see if it helps. I've pasted the link below.
https://community.pega.com/support/support-articles/data-import-fails-when-fields-contain-crlf-chars
TR
No Parthasarathy
I removed spaces from my file path(V:\BEDDİBEYVEMMMXXBEYİNÅUBEYETKİSİNDEKİKRDİLEREAİTFARKLILIKLARHKUYGUNLUK) still I am getting same error.
