Verizon
Last activity: 6 Jul 2016 11:56 EDT
Intermittent "rule with a bad defined-on class" error shows up on Connect-SOAP operation on tracer in Pega 7.1.8 Version, Are there any changes required to fix this error . As per PDN the issue was resolved with 7.1.8
Hi Anuj, Good morning!
- SR-A16032 is a similar issue raised on Pega 7.1.7.
- The SR is 'Resolved-MaintLevel' with resolution note as "This issue is resolved in update release 7.1.9"
- also please copy the PDN link where it says the issue is resolved in 7.1.8.
Thank you!
psahukaru
Verizon
Hi Phani,
Please find the URL below
SA-17989
SUMMARY
Intermittently, an error saying " Attempting to access a rule with a bad defined-on class: ___ is seen during soap-connect operations.
ERROR MESSAGES
Attempting to access a rule with a bad defined-on class: .
STEPS TO REPRODUCE
An alert is generated if a soap-connect operation takes more than 1 second and the issue occurs.
ROOT CAUSE
The message-reporting logic in the alert layer was missing the pxObjClass of a Rule-Message, which caused the error.
RESOLUTION
This issue has been resolved in the Pega 7.1.8 platform.
also could you please confirm the behavior with SA article - https://collaborate.pega.com/question/required-information-swift-net-ei-framework
Verizon
It's the same issue as mentioned on article https://collaborate.pega.com/question/required-information-swift-net-ei-framework
Verizon
Do we have any hot fix for this issue for 7.1.8?
sorry Anuj, i'm not sure if we've a hfix for this issue on 7.18. please contact Pega global support team.
Hi Anuj,
Do let us know here if you open an SR with Pega GCS so that we may track it through this post!
Lochan
Upon reviewing the associated SR with this post, I see that the SR has been withdrawn. I will be closing this discussion. If this occurs again, please re-open this post Anuj.
