Cognizant
Last activity: 20 Sep 2016 9:21 EDT
Cache Configuration
on PRPC6.2 ENV do we need to maintain separate cache directory (prtemp) for individual jvm which are in same UNIX BOX HOST?.
I believe common cache directory for all jvm's on unix box will reduce the DB calls for generating cache. And also reduce the load on system pulse/system cleaner to synch cache and delete the stale cache things.
But would like to understand the conflicts to do this. Please provide your data points for pros and cons..
each jvm needs to have its own pega temp directory otherwise there will be some unforeseen behavior. This is explicitly in the latest pega 7 installation guide, e.g., https://docs-previous.pega.com/pega-72-platform-installation-guide-tomcat-and-oracle
Setting multiple nodes to the same pega temp directory is not an option. You may not see issues right away but we have seen some weird behavior due to this setup.
