MacIf
FR
PRPC 6.2 SP 1 Authentication Profile for SOAP and Global Ressource Settings
I'm trying to use an basic authentication for a webservice, and my authentication profile works only when i didn't use Global Ressource Settings to set the password (it's work with the username).
But when I use a hardset password it works, so my credentials are correct.
Anyone have already see this and fix it ? Maybe with a Hotfix?
MacIf
FR
Hello everyone,
Just to let you, the HFix-6837 fix the issue.
Thanks for the help,
Regards
Hi Gregory, Good morning!
- Is the password provided from declare page encoded in base64 format?
- or the value for password field is noticed blank?
Thank you!
psahukaru
- can we pass the authentication details via Authorization Header? (does the service support & make sense to test??)
Updated: 25 Apr 2016 3:08 EDT
MacIf
FR
I don't know if the password from is base64 format. but it's standard alpha caracters in my password like abcde..xyz
I have try with a non declare and it's the same result.
When I look the log of the webservice, i can see that the password received is =PageName.PropertyName .It seems that Pega don't look this like a property's reference.
We can't use the authentification in the header. I have to use a basic authentication.
Please check if you have HFix-5619 installed on your system.
MacIf
FR
No.
This hotfix is not install.
Please get this hotfix. This should resolve the issue you are seeing.
Hi Gregory,
Please create a Support Request with Pega GCS to receive the hotfix.
https://collaborate.pega.com/question/how-raise-sr-my-support-portal-how-question
- Please select Request Type as Existing Hotfix Request to receive this particular hotfix!
- Do let us know the SR number here if you end up raising it, so that we may track it through this post.
Lochan
MacIf
FR
I have the SR.
Keep you in touch thanks.
UnitedHealth Group
Hi Gregory,
Can you please add how you are referring to Global Resource Settings for the password?
Prasad
MacIf
FR
I use =DeclarePageName.PropertyName
MacIf
FR
Hello everyone,
Regards
Swedbank
SE
Hi everyone,
I am also facing similar issue in 7.1 version where when passing pagename.propertyname for password, it is not taking whereas for username it is working fine if password is hardcoded. Should i also install the same hotfix?
Any help is appreciated.
Hi Prashanth,
I see that you have created duplicate thread for this query. Request you to continue the troubleshooting in this thread- https://collaborate.pega.com/question/passing-passwords-property-value-authentication-profile
Thanks!
Swedbank
SE
Hi Vidyaranjan,
Since i saw the same issue which i faced, hence replied back on the same thread as i tired the steps mentioned and facing the same issue.
Prashanth
