Last activity: 11 May 2016 11:00 EDT
Pega 7 New Application Wizard Doesn't have a mechanism to introduce a Shared Layer like 6.2 What are the alternatives?
In New Pega 7 new Application Wizard there is no mechanism of introducing a Shared Layer like what 6.2 had. What are the alternative i just don't want to manually create it after generating the application.
Eg:- Lets say my Proposed class structure is :-
Framework:- Org-FW-DeptFW-SharedLayerFW-Work
Implementation:- Org-Div-Unit-Dept-SharedLayer-Work
Now in previous 6.2 Application Accelerator there was a screen where you can specify the Shared Layer in the New wizard there is nothing. Only thing it generates is :-
Framework:- Org-FW-DeptFW-Work
Implementation:- Org-Div-Unit-Dept-Work
Now the only option is to create it and then refactor the class to change the name and create the shared layer manually. But i don't want to go that route. Any Alternatives folks?
