HCL Technologies
ZA
Last activity: 27 May 2016 22:37 EDT
Error while running process flow
Rule— Unable to open an instance using the given inputs: Rule-Declare-DecisionTable Main-HRService-Work-Candidate.CandidateQualification
Please help
Message was edited by: Marissa Rogers - marked as a question/added category
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689954000/5e1df259-88ec-40db-aa4a-a5b27280a5f7.jpg?itok=ChGegHBG)
Hi Deepak,
Can you provide more detailed information about your process flow?
Susan
HCL Technologies
ZA
HCL Technologies
ZA
I need assistance for the above process flow. could anyone help in resolving and making me understand where I am going wrong as none of the process flows are working giving rule error as above process flow
Hi Deepak,
Just delete the connectors and re-join again. It might solve the issue.
Ravi
Pegasystems
When I click your picture, it is not coming up any bigger, so it is hard to read the error. Did you paste that picture in firefox browser perhaps? We have had issues where that method of pasting pictures prevents them from showing large enough. /Eric
HCL Technologies
ZA
Hi, I tried deleting the connector and re-join it its giving same error. Also it gives error in Connector Properties-Flow Action... If I mention Collect Personal Info its not recognizing saying invalid reference.
I dn't where I am wrong but if anyone can help..
The few times I've experienced this I wiped out all the shapes and started again, I've never been able to determine a root cause in misconfiguration.
Citicorp Services India Private Limited
Hi Deepak,
Could you please verify whether the flow action rule present in "Main-HRService-Work-Candidate" class or the in any of the parent. if the rule is not present, could you please the flow action rule in the flow class?
for rest of the errors "This connector does not originate from a valid shape" make sure the connections are proper as shown below.
If there is any green color on the connector edges on clicking the connector shape, then the connection is invalid as shown below.
Drag the edge over the Assignment shape and you will see the connector points to link the connection.
Please let us if this solves your issues.
Gowrishankar.
HCL Technologies
ZA
Hi, Thanks for reply.... It is present in Main-HRService-Work-Candidate class.
Any solution?
