Error while running flow rule
Are you trying to run a FW class flow?
Answer:- I am running (HDFC-FW-HDFCBank)FW flow (under Action--> run I am Clicking)
Then I am getting above error.
could you please provide necessary information to resolve the issue
@G Pavan As I previously mentioned we dont actually run the fw flows but if this is your need, please open HDFC-FW-HDFCBank class and check if this is a class group or belongs to a class group or others.
@G Pavan Could you provide more context at to which flow(class) you are trying to run? Are you trying to run a fw class flow? If Yes, ideally we should not be doing it, if no can you open the HDFC-HDFCLoans-Work class and see if the class keys are defined additionally click on test connectivity button to check if it is mapped to a table in database and there are no errors/issues.
