Caught Exception while parsing XML Stream using Apply-Parse-XML
When I am trying to parse the XML using Apply-Parse-XML method, it is getting failed with exception "Fail: Caught exception parsing XML stream".
There is nothing much in logs as well. I can just see the following entry in log.
When I run the Parse XML rule and provide the same XML as input it works fine.
Could not see anything in the tracer as well, it just throws the same exception - Fail: Caught exception parsing XML stream
Has anyone come across such an issue? Is there any hot-fix for the same?
Any help in this regard will be appreciated.
Version: PEGA v7.1.6
