TATA Consultancy Services Ltd
Last activity: 2 Dec 2016 4:25 EST
How to call a flow action from activity in 6.2 sp2.
How to call a flow action from activity in 6.2 sp2.I have a Drop-Down(Dynamic select) on a section ,(The section is placed on harness) on selecting one of the option an activity is called and The flow action will needs to be open in the modal dialog box.Please describe it step by step manner.
Pegasystems
I don't know, but here's how I suggest you find out:
Start with a real flow with at least one assignment, and put your flow action as one of the allowable LOCAL actions for the assignment.
Trace what we do when you choose that LOCAL action. A number of the activities you see performed will be the same ones you'll need. It's probably just one or two activities that already exist, and they call everything else for you.
/Eric
Updated: 2 Jun 2016 14:22 EDT
- would it be convincing to try the following steps?
- call harness from activity [Call Show-Harness or UIActionDisplayHarness]
- drag & drop the section in harness [RULE-HTML-SECTION @BASECLASS PXLOCALACTION]
- Pass appropriate parameters for pxLocalAction
Please share your thoughts/comments, Thank you!
psahukaru
call OOTB @baseclass processAction activity from your activity. It renders flow action from the activity.
Also pass these parameters to processAction activity from the calling activity:
your flowaction name as NewTaskStatus, StreamType as "Rule-HTML-Section", StreamClass as "Rule-HTML-Section".
If you need it in a modal dialog, pass modal template name as ActionSection and bIsModal as true.
Youness Wardaoui
processAction activity does not work,it shows error.can any one pls help
I have used the same thing in our application. It is working. Can you specify the error details?
Tata Consultancy Services
What is the ActionSection when we are passing the flow action name as TaskStatus. What is it? Can you please provide a set of sample parameter values you have used in below format.
TaskStatus = "XYZFlowAction"
StreamClass="Rule-HTML-Section"
etc.,
Infosys
i tried with parameters but it was not coming
CTS
I Tried but not working
