Salame
Last activity: 10 Jun 2016 4:44 EDT
"IS NOT IN" Operator inside a report definition
Cognizant
Hi Rosy
Can we pass the Template.ReleaseID in the report filter and put not in condition. May be if I did not understand correctly, can you put a screenshot of what you are trying to achieve.
Sam
Cognizant
Hi Rosy
Have you tried Does Not Contain Option.
Sam
Salame
Hello Samanth,
Thanks a lot, however, my condition in the filter should be dynamic. Please find below my scenario:
I have 2 classes: Template and Release. Inside Template class, I have a page of Release class. My report is based on Release class, I want to add a filter on it to exclude all releases that are assigned to templates, That's why, I was thinking of adding NOT IN condition , so it will be NOT IN (template.ReleaseID)
Do you have another suggestion?
Thank you,
Rosy
Cognizant
Hi Rosy
From your comments I assume that Release class page is of type list.
If this is a a page list class then you can define declarative index on release class and put the condition with Not In or Does Not Contain. Hope it will solve your issue.
Sam
Salame
Hi Sam, it is a single page. not a pagelist, as I should store a single value. Is that doable?
Rosy
Cognizant
Hi Rosy
Sam
Salame
This is what I wanted to do , but, there is no NOT IN operator in the filter
Cognizant
Can you put the same condition and see if does not contain works.
Salame
Hi Samanth, it worked for me after creating a sub-report and using not equals, thanks a lottttt
Salame
Hello Fani,
Thank you,
Rosy
Pegasystems
Is Not Equal will generate a NOT IN if multiple values are present. If a single value is present it will use the != operator.
Salame
Indeed! I have tried that and it worked!
Thanks a lot Rajiv for your answer!
Rosy
