![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689992000/eb24bfb5-4f05-48eb-b967-38634e5e566a.jpg?itok=DS0XaGXK)
Bits In Glass
Last activity: 18 Jun 2016 3:59 EDT
Soap Service Error
Hi there,
I have tried the Soap integration tell me where i have configured it wrong.
please find the attached.
Bits In Glass
I finally figured out where the error was:
till today i thought if
X is an input and has A and B as its child
if A is given as Parse and B is given as Stream it will fix it.
but,ain't it a common sense that whatever the response is needed it must be set prior to it in the request?that is what i figured out.
Now i am getting the output as i have set A as input and A as output too.
so no error of "Inbound data mapping failed".
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689969000/a69e934a-3d8b-48e6-a8fa-4aea6bb74014.jpg?itok=dWH8exwH)
Your service package has Requires authentication checked and the authentication type is Basic. In your connector, you need to select Use authentication and provide an authentication profile with auth type set as Basic. Looks like the service is returning 401 (Unauthorized) as the connector isn't providing Basic credentials in the request. Pega logs may contain details of the error.
Bits In Glass
Hi Praneeth,
Please find the log below.
2016-06-08 20:57:21,326 [http-bio-8686-exec-9] [ STANDARD] [ ] [ NewWebAP:01.01.01] (nternal.mapping.ParseRuleUtils) ERROR KANDURI| Proprietary information hidden|SOAP|NewService|WENOGOOD|SampleSoapTest|A4349D968AABDF63DD13B6495BC78E8E5 - Failed to open Rule-Parse-XML record: Wenogo-NewWebAP-Work.Parseintegration.myCreation
2016-06-08 20:57:21,328 [http-bio-8686-exec-9] [ STANDARD] [ ] [ NewWebAP:01.01.01] ( internal.services.ServiceAPI) ERROR KANDURI| Proprietary information hidden|SOAP|NewService|WENOGOOD|SampleSoapTest|A4349D968AABDF63DD13B6495BC78E8E5 - SOAP service [NewService][WENOGOOD][SampleSoapTest] failed:Inbound data mapping failed:com.pega.pegarules.pub.services.ServiceException: Inbound data mapping failed
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.mapInputData(ServiceAPI.java:1835)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.activityExecutionProlog(EngineAPI.java:554)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:383)
at sun.reflect.GeneratedMethodAccessor65.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
Hi Praneeth,
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.integration.engine.internal.services.soap.SOAPService.invoke(SOAPService.java:579)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:240)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374)
at sun.reflect.GeneratedMethodAccessor64.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:646)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:503)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:421)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
Caused by: com.pega.pegarules.pub.PRException: Failed to open Rule-Parse-XML record: Wenogo-NewWebAP-Work.Parseintegration.myCreation
From: (A4349D968AABDF63DD13B6495BC78E8E5:NewService)
at com.pega.pegarules.integration.engine.internal.mapping.ParseRuleUtils.lookupXMLParseRule(ParseRuleUtils.java:673)
at com.pega.pegarules.integration.engine.internal.mapping.ParseRuleUtils.invokeXMLParseRuleWithParam(ParseRuleUtils.java:1502)
at com.pega.pegarules.integration.engine.internal.ServiceHelper.applyXMLParseRuleWithParam(ServiceHelper.java:7001)
at com.pega.pegarules.integration.engine.internal.ServiceHelper.setInboundDataValue(ServiceHelper.java:1611)
at com.pega.pegarules.integration.engine.internal.ServiceHelper.mapInboundData(ServiceHelper.java:1458)
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.mapInputData(ServiceAPI.java:1755)
... 46 more
2016-06-08 20:57:21,407 [http-bio-8686-exec-2] [ STANDARD] [ ] [ NewWebAP:01.01.01] ( internal.mgmt.Executable) ERROR localhost| Proprietary information hidden|Rule-Connect-SOAP.Wenogo-Int-Localhost-WENOGOODService.SampleSoapTest Admin@wenogood - Exception
com.pega.pegarules.pub.services.RemoteApplicationException: SOAP service failed
at com.pegarules.generated.activity.ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.step15_circum0(ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.java:3994)
at com.pegarules.generated.activity.ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.perform(ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.java:308)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3505)
at com.pegarules.generated.activity.ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.step8_circum0(ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.java:1037)
at com.pegarules.generated.activity.ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.perform(ra_action_invoke_c28ff8c27ac24045d30f5561679549d1.java:189)
at com.pegarules.generated.activity.sh_action_connectoractivity_15d15167e0fd8d30e66723d23c9511eb.step1_circum0(sh_action_connectoractivity_15d15167e0fd8d30e66723d23c9511eb.java:261)
at com.pegarules.generated.activity.sh_action_connectoractivity_15d15167e0fd8d30e66723d23c9511eb.perform(sh_action_connectoractivity_15d15167e0fd8d30e66723d23c9511eb.java:71)
at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3238)
at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.step1_circum0(ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.java:175)
at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.perform(ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.java:69)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10563)
at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.step11_circum0(ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.java:1009)
at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.perform(ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.java:245)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:461)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3358)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:385)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:852)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:92)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
Caused by: com.pega.apache.axis2.AxisFault: SOAP service [NewService][WENOGOOD][SampleSoapTest] failed:Inbound data mapping failed
at com.pega.apache.axis2.util.Utils.getInboundFaultFromMessageContext(Utils.java:531)
at com.pega.apache.axis2.description.OutInAxisOperationClient.handleResponse(OutInAxisOperation.java:375)
at com.pega.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:421)
at com.pega.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229)
at com.pega.apache.axis2.client.OperationClient.execute(OperationClient.java:165)
at com.pegarules.generated.activity.ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.step14_circum0(ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.java:3891)
at com.pegarules.generated.activity.ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.perform(ra_action_invokeaxis2_f7d45a554d504ab39417e17167b6d28c.java:291)
... 64 more
2016-06-08 20:57:21,412 [http-bio-8686-exec-2] [ STANDARD] [ ] [ NewWebAP:01.01.01] ( internal.mgmt.Executable) ERROR localhost| Proprietary information hidden Admin@wenogood - Exception
... 64 more
2016-06-08 20:57:21,417 [http-bio-8686-exec-2] [ STANDARD] [ ] [ NewWebAP:01.01.01] ( internal.mgmt.Executable) ERROR localhost| Proprietary information hidden Admin@wenogood - Exception
... 64 more
2016-06-08 20:57:21,419 [http-bio-8686-exec-2] [ STANDARD] [ ] [ NewWebAP:01.01.01] ( internal.mgmt.Executable) ERROR localhost| Proprietary information hidden Admin@wenogood - Exception
... 64 more
2016-06-08 20:57:21,420 [http-bio-8686-exec-2] [ STANDARD] [ ] [ NewWebAP:01.01.01] ( internal.mgmt.Executable) ERROR localhost| Proprietary information hidden Admin@wenogood - Exception
... 64 more
2016-06-08 20:57:21,421 [http-bio-8686-exec-2] [ STANDARD] [ ] [ NewWebAP:01.01.01] (ngineinterface.service.HttpAPI) ERROR localhost| Proprietary information hidden Admin@wenogood - Proprietary information hidden: com.pega.pegarules.pub.PRRuntimeError
com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:712)
Caused by: com.pega.pegarules.pub.services.RemoteApplicationException: SOAP service failed
... 48 more
... 64 more
You need to find the root cause of this error:
The look-up of Parse XML rule referenced on the request tab of your Service SOAP rule is failing. Does the operator whose credentials you mentioned in the authentication profile used by the connector have access to the ruleset in which this Parse XML rule is present?
Bits In Glass
Bits In Glass
