Lloyds Banking Group PLC
Last activity: 30 Jul 2015 9:32 EDT
SOAP Service returning error
I am new to SOAP integration and had been working with a SOAP service. I generated the WSDL and uploaded into SOAP UI for testing. When i run the WSDL by proving some parameters in SOAP UI, there is an error throwing during run time. The error is as follows.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<SOAP-ENV:Body>
<SOAP-ENV:Fault>
<faultcode>SOAP-ENV:Server</faultcode>
<faultstring>Couldn't parse SOAP request envelope</faultstring>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
WSDL is
<soapenv:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:PegaRULES:SOAP:AWDPackage:LTSSI-Work-MsgCase-Scanning">
<soapenv:Header/>
<soapenv:Body>
<urn:CreateNewScannedMsg soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<InquiryDate xsi:type="xsd:date">?</InquiryDate>
<transactionRef xsi:type="xsd:string">?</transactionRef>
<caseIndexDocId xsi:type="xsd:string">?</caseIndexDocId>
<InquirerName xsi:type="xsd:string">?</InquirerName>
<InquirerID xsi:type="xsd:string">?</InquirerID>
<InquiryAmount xsi:type="xsd:decimal">?</InquiryAmount>
<awdObjectKey xsi:type="xsd:string">?</awdObjectKey>
<Currency xsi:type="xsd:string">?</Currency>
<casetype xsi:type="xsd:string">?</casetype>
</urn:CreateNewScannedMsg>
</soapenv:Body>
</soapenv:Envelope>
I am not sure how to debug this as the error code indicates
The SOAPMessage object could not be processed because of a processing error, not because of a problem with the message itself. |
I am using SOAP 1.1 specification and want to understand how can I debug the problem.
