Personly
Last activity: 9 Jul 2016 9:56 EDT
How to find field value inspector in pega 7.2?
Hi all,
I am trying to figure out how to adjust localised values.
From the help files and PDN i understand the field value inspector tool can help to show which field value is used to translate in the context in which it is shown
tho i can't seem to figure out how to access the tool.
I dont see the field value inspector, nor the inspector prefs at the developer toolbar.
Can anyone point me in the right direction?
Thanks in advance!
Message was edited by: Marissa Rogers - Added Category
Updated: 10 Jun 2016 14:21 EDT
Hi Cornelis,
I did a PDN search on this and I found the following:
Examining field values with the Rules Inspector tool
To aid in localizing user forms, you can easily identify and update field values referenced in a harness, section, or flow action. Select
> Rules Inspector > Field Value Rules to enable or disable this capability. See Rules Inspector tool — Localizing with the Field Value Inspector.
Does that help you in locating this tool?
- I don't think field value inspector feature existing in Pega 7.2 version. it might come in future releases. please correct otherwise. Thank you!
The link I provided came from Pega 7.2 Help.
Personly
Thanks Phani.
Pegasystems
I think that pdn info needs updating. In particular, that little triangle shown in this reference:
Select
I don't think that little triangle exists in Pega 7.2. If not, is it still possible to turn on field value inspection?
For Pega 7.2, would the "live UI" feature be of use here? It is a symbol at the bottom of the developer portal, near the tracer and clipboard symbols.
/Eric
Thanks Eric! I'll investigate this further and get back with more information when I have some.
Updated: 10 Jun 2016 17:04 EDT
Pegasystems
I did a bit of peeking under the hood on prpc 6.2sp1. On that system, which does have the UI that Marissa cited, the following steps allow toggling field value inspection without using the UI cited by Marissa.
1) From developer portal, click the "run" icon on the activity form for the pzUpdateRulesInspectorOption activity.
2) On the popped up "run" box, give value "Field" (I gave it without the quotes when I tried it) for the mode parameter.
3) Click "run", and your field values will be toggled, which you can demonstrate by starting any flow and observe the field value icons on the "new" harness".
However, when I tried those steps on a Pega 7 system, I did not see the field value icons. /Eric
Personly
Thanks for your assistance Eric. Its clear to me now that i was searching for something not existing..
This feature will be provided in an upcoming version of Pega 7 and as Eric guessed, will be part of the Pega 7 UI tooling.
Personly
Thanks Marissa, that clears it up.
Thanks Cornelis Uijttewaal! If your question was answered, please mark that reply as Correct Answer.
AI4Process Ltd
As an alternate solution, you can use UI inspector. Click on required field in section, from UI inspector click on "open property panel", which will show the cell properties. This is as good as Field rule inspector.
available in 7.2.1
available in 7.2.1
available in 7.2.1
available in 7.2.1
