[ML8] Ruleset Required in Branch Application
We are creating a new branch application for a team, but it is throwing an error requiring at least one Ruleset.
This is not correct based on this Pega7 Help. Is there a HFix available for this? We are using ML8.
thanks,
Will
Creating a team application
First, create a team application that is built on the main application by doing the following.
thanks,
Will
- In the Application Explorer, create a new application rule by right-clicking the application and selecting +Create > Application Definition > Application.
- In the Create Application form, enter the name for the application in the Label field.
- Enter a version in the Version field.
- Select an available ruleset into which to save the rule from the Add to ruleset drop-down box.Note: You can update the ruleset for the application using the Advanced tab on its rule form. It has no effect on the teams using branches for development.
- Click Create and open.
- In the application rule form, in the Name field, select the name of the main base application.
- In the Version field, select the version of the main base application.
- Select the Include Parent checkbox.
- Ensure there are no items listed for the Application rulesets before saving the rule form .
- Click Save.
- A warning appears in the rule form to alert you that the application rule is saved to a ruleset that is not part of the application's ruleset list. This situation is acceptable for a team development application. To remove display of the warning, you can use the Add Justification link.
- Give team member access to the team application.
