Accenture
Connect Http is blanking out " " and passing blank values.
Issue: Connect Http is blanking out " " and passing blank values.
Impact: Service is failing as null values are getting passes.
We upgraded from Pega 5.5 Sp1 to Pega 7.1.8.
In 5.5 " " value was getting appended in URL as +
In 7.1.8 " " value is getting appended as blank
Due to this service is failing as with error-Cannot assign MRM-defined null value. Nulls not allowed for this element.
For debugging did below steps,
1. Passed "+" value through request parameter in Connect Http rule. It takes it as blank only.
2. Passed any constant value 0,1..; it passes; but we need to pass the blank value, i.e. " "
3. Debug mode for InvokeHTTPRequest activity was made active. Focus on sessionText
Pega 5.5 log file line of request when debug is turned on for the InvokeHTTPRequest activity:
https://...sessionText=+&bus...
Pega 7 version of log output:
https://...sessionText=&bus....
Can anyone, please suggest.
