CSA certificate is required
Hi Team,
I have completed CSA pega 7.1 V1 exam successfully on 5th September 2015.
Requesting to please share the required completion certificate.
Regards
Rekha Kumaresan
Hi Team,
Regards
Rekha Kumaresan
Rekha
I have forwarded your request to our Certification Department. My hope is they will respond here, otherwise I will follow up once I hear via email.
Sean
Pega Academy Support Tem
Rekha
You can view and download the PDF in Pega Academy:
Step 1: Click View Transcript:
Step 2: Click Download:
Hope this helps,
Sean
Pega Academy Support Team
In View Transcript, i could able to see my online Course certifications but not CSA 71V1- Exam scrore report with Candidate ID: PEGA026273 completed on Sep 5th 2015. Please advise. Thanks..
Rekha
Are you looking for your Exam Score Report or your Certification of Completion of CSA?
If you are looking for you Exam Score Report you can find this by logging into www.vue.com/pegasystems and clicking the View Score Reports on the right column under the My Account heading. From there you should be able to find the CSA exam and bring up your score report.
If you are looking for your Certificate of Completion of CSA you should be able to download it using the steps I mentioned in my earlier post. Both Instructor-Led and Online Course Certification of Completions as well as Certificates of Completions of Certifications are available from here.
Please let me know if this solves your issue.
Sean
Thank you so much for your reply!!
