List all properties of a Clipboard Page in Java
How to list all properties of a Clipboard Page in Java?
Hi Jaya,
You can use below code to refer all the properties in clipboardpage
ClipboardPage interface has below method that can be leveraged.
java.util.Set entrySet()
Use the iterator() method of the returned object to perform an operation on each property in turn. Note that this iterator reflects the contents of this page at the time of its creation. Further changes to this page will not be reflected in this iterator.
entrySet in interface java.util.Mapplease refer java step in OOTB activity
RULE-OBJ-ACTIVITY @BASECLASS CLIPBOARDVIEWER_GETPAGEUPDATEXML
Here you go, include a Java step in your activity and use this code
try {
ClipboardPage clipboardPage = tools.getStepPage();
//Or ClipboardPage clipboardPage = tools.findPage("<page name>");
oLog.infoForced(clipboardPage.getXML());
java.util.Iterator itr = clipboardPage.values().iterator();
while(iter.hasNext()){
ClipboardProperty prop = (ClipboardProperty) iter.next();
oLog.infoForced(prop.getName() + ": " + prop.getModeName());
}catch(Exception ex){
oLog.infoForced(ex.getMessage());
try {
try {
} catch(Exception ex){
e.printStackTrace();
Here we are getting the clipboard page first and then we are getting the values. Iterating each value assigning that cilpboardProperty.
