Can we reference connector rules in Flow rules?
Can we reference a connector rule from Flow rule? If yes, could you please some reason and already available example.
Thanks in advance!
Thanks in advance!
We can use Integrator shape in the flow rule.
Any already available example of this in PRPC?
Simply add an "Integrator" Advanced Shape from the "Advanced Shapes" pallet of the "Flow Shapes" pull down or pop-up menu while editing the Flow Rule in the Flow Rule Form. You can then connect the integrator shape to the flow at the point you want to invoke the Connector Rule. To actually invoke the Connector Rule you will need to call an Activity Rule from the Integrator Shape. You can create the required Activity Rule by using one of the Pega Designer Studio Connector Wizards (DesignerStudio>Integration>Connectors>...). Please consult with a Senior System Architect on you project to help you create the requisite Connector Rule and associated Activity Rule.
Henry
Pega Academy
Hi Henry,
Thanks for the explanation. It means we can reference connector rules only from Data-Page & Activity directly, and indirectly from Flow.
Then in that case, the answer should be in this context. "NO". Please confirm!
Hi Chopp,
That is correct; there is no Shape that you can add to a Flow Rule that directly references a Connector Rule.
Henry
Pega Academy
