Sunlife
Last activity: 12 Nov 2015 2:08 EST
Defer load
I want to know how to execute an activity defined on defer load of a tab by simply refreshing the section again. For more clarity, let me explain the scenario,
I have a tabbed section, tab1 ,tab2 ,tab3.
On tab 3 , I have a defer load activity which will call a service using connect soap and response will be displayed on the tab3 section. In case of service failure ,error message will be displayed.
Now I want to retry the service without loading entire harness or whole tabbed section.
I tried placing abutton and configured to refresh this section.Section gets refreshed, but defer load activty doesnt executed.
Kindly suggest is there any approach for this .
Note: I dont want to reload entire harness or section where all the tabs are included.
Thank you for your question. You can try to call the defer load, pre-loading activity on the tab layout which will get the data for you to display when the person clicks on it. See below:
Lu
The Pega Academy Support Team
