getting 503 error
What is the issue in this,Because of what i am getting 503 error when i start login button.
2015-05-26 13:34:15,539 [ocalhost-startStop-1] [ ] [
] [ ] (l.access.ConnectionManagerImpl) INFO - Defined
by: JNDI name
] [ ] (l.access.ConnectionManagerImpl) INFO - Data sou
rce name: java:comp/env/jdbc/PegaRULES
] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum
connection count: 0
] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum
connection count: unlimited
] [ ] (l.access.ConnectionManagerImpl) INFO - Failover
database: none
2015-05-26 13:34:15,601 [ocalhost-startStop-1] [ ] [
] [ ] ( external.timers.CpuTimer) INFO - CPU timers
set to TOTALSONLY. Use prconfig setting 'initialization/CpuTimerLevel' with one
of [FULL, TOTALSONLY, NONE] to modify.
] [ ] (.timers.EnvironmentDiagnostics) INFO - Using Java
1.5 Thread.getAllStackTraces() for thread dumps
Using sun.misc.Perf high-resolution timer for elapsed timings
Using Java 5 Management beans for thread CPU timings.
Using Java 5 Management beans for process CPU timings: 6973244700
2015-05-26 13:34:15,648 [ocalhost-startStop-1] [ ] [
] [ ] (.access.PageDatabaseMapperImpl) INFO - DeflateStre
ams is turned ON.
2015-05-26 13:34:15,663 [ocalhost-startStop-1] [ ] [
] [ ] (pboard.StorageStreamCommonImpl) INFO - engineCodeV
ersion: 07-10-15
2015-05-26 13:34:15,866 [ocalhost-startStop-1] [ ] [
] [ ] ( internal.mgmt.PRNodeImpl) INFO - Using codes
et version and timestamp map: {pega-enginecode=07-10-15@2014-12-29 10:47:00.0, c
ustomer=06-01-01@1970-01-01 05:30:00.0}
2015-05-26 13:34:15,944 [ A169DBLR] [ ] [
] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated s
ource : file://runtime:/PRGenJava/
] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated c
lasses: file://runtime:/PRGenClasses/
] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-
tier real root path: D:\PRPCPersonalEdition\tomcat\webapps\prweb
tier temporary path: D:\PRPCPersonalEdition\tomcat\work\Catalina\localhost\prweb
] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaR
ULES real root path: D:\PRPCPersonalEdition\tomcat\webapps\prweb
] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES
effective root path: file://default:/
effective temp path: D:\PRPCPersonalEdition\temp
Using genSourcePath: file://runtime:/PRGenJava/
] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genC
lassPath (database): pegajdbc://2015633989:1/
enClassPath (files): file://runtime:/PRGenClasses/
external classes in: <not using external classes>
ng external jars in: <not using external jars>
2015-05-26 13:34:16,007 [ A169DBLR] [ ] [
] [ ] (rnal.mgmt.InitialConfiguration) INFO - Servlet cla
sses: D:\PRPCPersonalEdition\tomcat\lib\servlet-api.jar
] [ ] (rnal.mgmt.InitialConfiguration) INFO - JSP cla
sses: D:\PRPCPersonalEdition\tomcat\lib\jsp-api.jar
] [ ] (rnal.mgmt.InitialConfiguration) INFO - EJB cla
sses: (none)
] [ ] (rnal.mgmt.InitialConfiguration) INFO - JMS cla
sses: (none)
2015-05-26 13:34:16,131 [ A169DBLR] [ ] [
] [ ] (rnal.access.CacheContainerImpl) INFO - Using the D
ynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment
of 102400.
2015-05-26 13:34:16,272 [ A169DBLR] [ ] [
] [ ] (pcentric.RACacheAppCentricImpl) INFO - Prune thres
hold is 10000
] [ ] (pcentric.RACacheAppCentricImpl) INFO - mFUAReusabl
eEnabled = true, mConstructorReuseEnabled = false, mFUAReusableEnabledStream = t
rue
2015-05-26 13:34:16,303 [ A169DBLR] [ ] [
] [ ] (pcentric.RACacheAppCentricImpl) INFO - Using RACac
heAppCentricImpl for assembly cache implementations
] [ ] (pcentric.RACacheAppCentricImpl) INFO - Assembly av
oidance will use branch ruleset optimization
] [ ] (nal.cache.AssemblyCacheWrapper) INFO - Assembly Ca
che Wrapper: configuredCacheType = AC
2015-05-26 13:34:16,350 [ A169DBLR] [ ] [
] [ ] ( internal.mgmt.PRRequestorImpl) INFO - RecordWorkI
nProgress is not enabled
2015-05-26 13:34:16,459 [ A169DBLR] [ ] [
] [ ] (orization.SessionAuthorization) INFO - RSL Update
Behavior: Eager
2015-05-26 13:34:16,521 [ A169DBLR] [ ] [
] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input
per interaction warning threshold: 50M
] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap us
ing multi-tenant environment: false
] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the
class group definitions
2015-05-26 13:34:16,568 [ A169DBLR] [ ] [
] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 36 cla
class definitions
2015-05-26 13:34:18,862 [ A169DBLR] [ ] [
] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 6007 c
lass definitions
2015-05-26 13:34:19,142 [ A169DBLR] [ ] [
] [ ] ( internal.access.DatabaseImpl) INFO - Database pr
oduct: PostgreSQL
] [ ] ( internal.access.DatabaseImpl) INFO - Database ve
rsion: 9.1.14
] [ ] ( internal.access.DatabaseImpl) INFO - Driver: Pos
tgreSQL Native Driver
] [ ] ( internal.access.DatabaseImpl) INFO - Driver vers
ion: PostgreSQL 9.2devel JDBC4 (build 1000)
] [ ] ( internal.access.DatabaseImpl) INFO - Version of
JDBC supported by driver: 4.0
2015-05-26 13:34:19,330 [ A169DBLR] [ ] [
] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES i
nitialization failed. Server: A169DBLR
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndIn
itialize(PREnvironment.java:392)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAn
dInitialize(PRSessionProviderImpl.java:1905)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.Engine
Startup.initEngine(EngineStartup.java:657)
Impl._initEngine_privact(EngineImpl.java:165)
Impl.doStartup(EngineImpl.java:138)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitia
lized_privact(WebAppLifeCycleListener.java:280)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitial
ized(WebAppLifeCycleListener.java:187)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBoot
strap.java:338)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropaga
tingThrowable(PRBootstrap.java:379)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invo
keMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
keMethod(AppServerBridgeToPega.java:265)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.c
ontextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContex
t.java:4994)
at org.apache.catalina.core.StandardContext.startInternal(StandardContex
t.java:5492)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:87
7)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:649)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1083
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:
1879)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: com.pega.pegarules.pub.context.PRSecurityException: Unable to constru
ct authorization core due to authorization failure
at com.pega.pegarules.session.internal.authorization.SessionAuthorizatio
n.<init>(SessionAuthorization.java:245)
at com.pega.pegarules.session.internal.mgmt.PRRequestorBase.allocateSess
ionAuthorization(PRRequestorBase.java:537)
at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.allocateSess
ionAuthorization(PRRequestorImpl.java:2009)
at com.pega.pegarules.session.internal.authorization.Authorization.reset
(Authorization.java:432)
(Authorization.java:381)
at com.pega.pegarules.session.internal.authorization.Authorization.onBef
oreThreadUse(Authorization.java:1624)
at com.pega.pegarules.session.internal.mgmt.base.ThreadPassivation.confi
gureThreadImpl(ThreadPassivation.java:316)
at com.pega.pegarules.session.internal.mgmt.PRThreadBase.configureThread
(PRThreadBase.java:176)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.<init>(PRThread
Impl.java:131)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.acquire(PRThrea
dImpl.java:146)
at com.pega.pegarules.session.internal.mgmt.base.RequestorThreadSync.get
OrCreateThread(RequestorThreadSync.java:175)
OrCreateThread(RequestorThreadSync.java:162)
OrCreateThread(RequestorThreadSync.java:158)
at com.pega.pegarules.session.internal.mgmt.base.RequestorPassivation.co
nfigureRequestorImpl(RequestorPassivation.java:477)
at com.pega.pegarules.session.internal.mgmt.PRRequestorBase.configureReq
uestor(PRRequestorBase.java:480)
at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.<init>(PRReq
uestorImpl.java:299)
at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.acquire(PRRe
questorImpl.java:323)
at com.pega.pegarules.session.internal.mgmt.base.MultiThreadRequestorFac
tory.acquire(MultiThreadRequestorFactory.java:61)
at com.pega.pegarules.session.internal.mgmt.base.NodeRequestorMgt.create
RequestorImpl(NodeRequestorMgt.java:1476)
RequestorImpl(NodeRequestorMgt.java:1456)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.initializeSystem(
PRNodeImpl.java:773)
itialize(PREnvironment.java:371)
... 28 more
Caused by: com.pega.pegarules.pub.context.InvalidConfigurationException: Data-Ad
min-Requestor instance "USTGlobalDev!BATCH" not found
n.reset(SessionAuthorization.java:446)
n.<init>(SessionAuthorization.java:241)
... 49 more
] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES i
2015-05-26 13:34:19,345 [ A169DBLR] [ ] [
] [ ] (ervlet.WebAppLifeCycleListener) ERROR - Enterprise
tier failed to initialize properly, PegaRULES not available
2015-05-26 13:34:19,361 [ A169DBLR] [ ] [
] [ ] (ervlet.WebAppLifeCycleListener) INFO - Web Tier in
itialization is complete.
May 26, 2015 1:34:19 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deployment of web application archive D:\PRPCPersonalEdition\tomcat\webapp
s\prweb.war has finished in 6,349 ms
May 26, 2015 1:34:19 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory D:\PRPCPersonalEdition\tomcat\webapps\
docs
INFO: Deployment of web application directory D:\PRPCPersonalEdition\tomcat\weba
pps\docs has finished in 78 ms
examples
pps\examples has finished in 172 ms
host-manager
pps\host-manager has finished in 62 ms
manager
pps\manager has finished in 47 ms
ROOT
pps\ROOT has finished in 47 ms
May 26, 2015 1:34:19 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-9090"]
INFO: Starting ProtocolHandler ["ajp-bio-9009"]
May 26, 2015 1:34:19 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 8174 ms
