"Run Script" action in CPMDashBoard section is not called
I need to call a function in a javascript contained in an iFrame. I added a button in the CPMDashBoardContainer section and called the run script action this way : "window.frames.iframeName.functionName" but the action is not called when I click the button.
The same scenario works perfectly in the CPMInteractionPortalHeader section/ the PopUp of the incoming Call... except in the body of the portal.
Anyone did it before?
Thank you!
