QBE
Last activity: 20 May 2015 10:39 EDT
Dynamic UI : Radio Button Source
I am practising Dynamic UI rendering, and have difficulties with the Radio Button values.
I am using Pega 7.1 personal edition.
I have configured a step with three properties.
1.) Customer Type (PropertyName: .CustomerType, Property Mode Text, Control type : Radio Button, UIControl: pxTextInput, table type: local list, Table Value: Business, Residential)
2.) Busines Customer : (PropertyName: BusCust; Property Mode: Object, Object Fields : Company Name, Company Address, VAT Number)
3.) Residential CustomerL (PropertyName: ResCust; Property Mode: Object, Object Fields: First Name, Last Name, Address)
Based on the Customer Type selection, I wanted to render Business Customer Object or Residential Customer Object.
I have configured When rules in Business Customer section rules and Residential Customer section rules.
When I run the case, and make selection on the customer type, I didn't get the Business Customer or Residential Customer section rendered.
However, when I set the default value to .CustomerType as "Business" or .CustomerType as "Residential", and then run the case, I could see appropriate section is rendered based on default value.
How do I enable the dynmic rendering based on radio button selection, Am I missing something here ?
Is my Customer Type selection on the UI doesn't get stored into the .CustomerType property value automatically.?
Any suggestion, comments on this is much appreciated.
Thanks.
Mathav
