Turkiye Finans Katilim Bankasi A.S.(TFKB)
TR
Last activity: 22 Nov 2016 20:05 EST
Unable to generate integration classes
Hi all,
When I try to generate integration classes, as I did several times before, this time it gives error:
Canceling rule generation, Unable to determine a unique class name for a repeating restriction after 100 iterations
Any idea?
Why it gives this error?
Thanx in advance
Abdullah
Hello Abdullah,
Thank you for your query. It has been passed to the appropriate members of our support team. Someone will contact you.
Andrew Fontenelle
PDN Support Team
TR
Hello Andrew,
Thank you for your reply :-)
Hope you remember me in the training of Turkey Finance team.
Regards
TR
Hi Andrew,
Nobody returned, and it's urgent. Could you help, please?
Abdullah
Pega customer support should look into this. Without the WSDL that was being loaded into the wizard at the time of the error, it will be impossible to infer what the problem might be.
Hello Abdullah,
Our support team has determined that this needs further investigation. In order to resolve the issue that you are experiencing a thorough review of all of the factors contributing to the issue is required. Please submit a Service Request (SR) so that one of our Customer Support technicians can work with you on this. You can do so by contacting Pegasystems Global Technical Support through My Support Portal.
Andrew Fontenelle
PDN Support Team
Hello Abdullah,
You can contact Pegasystems Global Technical Support through this link My Support Portal.
Andrew Fontenelle
PDN Support Team
TR
Thank you Andrew, I'll follow this path.
MSG-Systems
DE
did you get a solution to this problem. I have the same problem right now.
Best
thanks
Jacek
Please provide more details. Pega version, steps to replicate the issue, complete logs, etc.
