Accenture
Posted: May 5, 2015
Last activity: Aug 18, 2015
Last activity: 18 Aug 2015 0:31 EDT
Is there any tools available that can help debug SSL handshake issue ?
Hello Rasaiya,
Thank you for your query. This has been passed on to our support team and someone will be in contact with you presently.
Andrew Fontenelle
PDN Support Team
Anyone aware any tool for debugging SSL handshake. Its really hard to debug SSL issue without any tool..
First choice is to turn on debug at the JVM level in the Pega app server using -Djavax.net.debug=all
Use OpenSSL’s “s_client” module to debug the SSL client, as described here: https://www.openssl.org/docs/apps/s_client.html
Thanks TANDP, this information was very usefull, i was able to use this, for debugging.
Thank you :D
Hi TANDP,
Do yo have any other link to open OpenSSL's"s_client module. As I am getting server not found error while hitting below URL.
