Optum
Last activity: 1 May 2015 8:43 EDT
Not able to login as [email protected]
Hello -
I previously completed the PRPC: Fast Track course and could log on to all the various roles used in that courses' excersizes. Now I am taking the DCO course. When I try to log onto Process Commander with the Proprietary information hidden login (PW: rules) I receive the message
The information you entered was not recognized.
I tried all the roles in the DCO course. I still am able to login using the roles listed in FastTrack.
Thanks for your help.
Bill Larson
are you referring to the DCO Essentials (7.1) course?
eddie
Optum
OK, I thought so, but wanted to be sure.
Let me spin up that vm and see what the issue is.
eddie
it seems I can login with the credetials:
Proprietary information hidden / rules
I'm curious. Are you using the original vm you downloaded for the PRPC: Fast Track course?
eddie
Optum
Yes. I keep suspending the session at the end of my day and resuming it when needed. Your question made me try shutting down PVS (using the command: sudo shutdown -h now) and restarting it. After which, I still am unable to login as Proprietary information hidden and am still able to log into other users from the FastTrack course (e.g. Architect).
Bill
The vm for PRPC: Fast Track does not have a login for Proprietary information hidden
You will need to download the specific exercise system (vm) for the DCO course. This vm is available for download in the Downloading the Exercise System lesson of the PRPC: Direct Capture of Objectives (v6.3) course.
eddie
Optum
Ah, Bach! That did the trick. Sorry, I should have realized this. Thank you for your help.
Bill
yw, good to hear you are up and running.
eddie
