Dynamically use parse rule in soap response
We have a requirement that with the value in soap header field we have to chose the Parse Rule to parse the response. How can this be achived?
STEPS:-
1. Map the response XML to a text property [say MessageResponse]
2. Parse the SOAP Message Header and get the required header field (say Message ID)
3. Maintain a decision table as shown below and set the desired Response Parse Rule (depending on Message ID)
Message ID |
Response Parse Rule |
Response Data transform |
if |
100 |
Parse-Rule1 |
Data-Transform1 |
Else if |
200 |
Parse-Rule2 |
Data-Transform2 |
Else if |
300 |
STEPS:-
Message ID |
if |
100 |
Parse-Rule1 |
Data-Transform1 |
Else if |
200 |
Parse-Rule2 |
Data-Transform2 |
Else if |
300 |
Parse-Rule3 |
Data-Transform3 |
Else if |
400 |
Parse-Rule4 |
Data-Transform4 |
4. Call the decision table and set the parse rule
5. Now use the above parse rule to parse the response.
I am using this approach in my current application.
Thanks Kiran. I too eneded up doing the same thing.
