Using Hover option
In a dropdown list instead of clicking can I use hover option? How can it be used?
Hi Arka,
If you are using Pega 7.1 you can use the "Actions" Tab of the Properties Dialog of the Cell that contains the Dropdown Control to "Create an action set" for the "Hover" Event to invoke the "Expand/Collapse" Action.
Henry
Pega Academy
Hi Henry,
I did as you told, but when I hover over the list it is not showing the list. It is only showing "Expand all" or "Collapse all" alternatively. And for viewing the list I had to click, what i want is that I will only hover over the dropdown item and the list will be displayed.
Thanks in Advance,
Arka
