Update Training material request - SYSTEM ARCHITECT ESSENTIALS II
Could you please update the BUILDING ASSIGNMENT FOCUSED (INTENT-DRIVEN) USER INTERFACES in the SYSTEM ARCHITECT ESSENTIALS II with a comment the note section on page 5. The comment should state if you get an error please try again after clearing your cache or try another browser to test.
Note: If you click the Run button to test your Create Employee Record step in the Onboarding case
type, but don’t see the UI section appear, ensure that you’ve done the Adding Default Data Transforms
exercise and that the Employee page properties have been correctly initialized for the Onboarding
process.
When using run in IE I received the following error:
The property pyWorkPage.pyWorkParty(Owner) was of mode String while com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.getPageValue() was expecting Page mode. Details: (none)
My first instinct was to try and resolve the issue and others repeated all the assignments again to check for mistakes. If the note state please try in other browsers as well then I and others would not of wasted so much time on this.
Craig
