Virtusa
Unable to pass large String text (XML) from Pega Connect SQL Rule to Oracle Database.
We are trying to call a stored procedure GetValues_SP from a Connect SQL rule in the application.
The stored procedure is defined in an Oracle database.
The Connect SQL sends a Text property (containing an XML string) as a parameter to the procedure as a CLOB.
The declaration of the CLOB is happening inside the Stored Procedure.
The length of my String is pretty big (larger than 32K). Hence, I am getting the following error:-
PLS-00172: string literal too long
Anyone else encountered this before? Please advise on what might be going on here?
