Unable to launch clipboard from User portal in IE 8 browser post upgrade to Pega7
We had a clipboard icon for administrator portal (custom portal) in our application, Copying from the designer studio footer, which belongs to Pega-clipboard class. After adding these icon on our portal, we are able to open it in Firefox and IE11 browser but unable to open in IE 8.
We are getting the following Error
INFO |WebContainer : 0|2015-06-11 05:42:21,601|Rule_Obj_Activity.ApplicationProfileSetup_WorkManager.Code_Security.Action|
-->Login: test444 (tstt admin) at 2015-06-11 04:42.21 as: Admin application: Phot 06.01.01|xxxxx.net|10.119.193.47|test444
ERROR|WebContainer : 3|2015-06-11 05:42:26,913|Rule_HTML_Section.pzClipboardHeader.Pega_Clipboard.Stream|Section 'pzClipboardHeader' execution error on page 'ClipboardPages' of class 'Pega-Clipboard'.|xxxxx.net|10.119.193.47|test444
java.lang.NullPointerException
at com.pegarules.generated.pzUseNewMenu_071015_BqgzS4u6_RJg84u5DF8AGg.pzUseNewMenu07_10_15(pzUseNewMenu_071015_BqgzS4u6_RJg84u5DF8AGg.java:97)
at com.pegarules.generated.pzUseNewMenu_071015_BqgzS4u6_RJg84u5DF8AGg.invoke(pzUseNewMenu_071015_BqgzS4u6_RJg84u5DF8AGg.java:70)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:133)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:110)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:8786)
at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181)
at com.pegarules.generated.pega_uiengine_pznavigation.pzUseNewMenu(pega_uiengine_pznavigation.java:358)
at com.pegarules.generated.html_section.ra_stream_pzclipboardheader_9c80c650cf6bf218a3a12ffc49356780.pxLink_1(ra_stream_pzclipboardheader_9c80c650cf6bf218a3a12ffc49356780.java:605)
at com.pegarules.generated.html_section.ra_stream_pzclipboardheader_9c80c650cf6bf218a3a12ffc49356780.simpleLayoutCell_3
