Jabil
Last activity: 9 Nov 2015 17:21 EST
Tree Layout dynamic row height?
Hello all. We're using a Tree Layout in 7.1.8 to display a section of varying height at each node. The Tree row height will only used a fixed width, though. Is this improved in a later release? We really need the heights to adjust according to the content, but now it truncates the bottom of the taller items.
A few ideas that you may try are to make adjustments in the Skin rule used by the application, also the Layout Properties Presentation tab also allows you to make adjustments that may be changed and may fix the issue.
Lastly refer to following PDN article for additional details.
https://community.pega.com/sites/default/files/help_v718/procomhelpmain.htm
The PDN Forum Support Team,
Lu
