Step will not delete after entering them
Hi Support,
I wanted to pass this along from a session yesterday I had with a client.
We were using the case designer on a new case. We entered some stages and steps. On the second stage we created a review step and underneith a Approve and Reject step. Based on step condition based on property one or the other would be skipped.
After testing this which worked we tried to delete the approve step as it wasnt needed. We clicked the X and it would disapear for .5 second and then reappear. We tried again, same thing. Closed the case and repopened and same. We couldnt get rid of the approve step.
Not sure whats up, but just wanted to pass it along. When the approve step showed up in UI it was the OOTB section, not sure if that helps at all.
Thanks, Jake
