Significance of px, py, and pz
Likes (4)
ALESSANDRO CRUD Rahul Choudhary Ganesh Agarwal Puja Chowdhury -
This Hungarian-style notation is not limited to database columns. These prefixes are used to identify Pega-provided artifacts (properties, data transforms, data pages, harnesses and sections, etc.). These prefixes are reserved for Pega, so you cannot create unique artifacts using any of these three prefixes.
In general terms, artifacts prefaced with py are Read/Write so can be overridden in your application. For example, you can use the .pyWorkPhone property in your application and present it on a UI screen for a user to update. You can also extend these artifacts by creating copies of them in your application.
In these same general terms, artifacts prefaced px and pz are Read Only - and cannot be overridden or extended by your application. The difference between these two artifacts (px and pz) is that artifacts prefaced with px are typically used to support your application. For example, when creating properties, you can specify the UI control type such as pxTextInput or pxDropdown. Artifacts prefaced with pz support (Pega) internal system processing.
Does this help clarify?
eddie
Jeeva Thambi Murali Manohar Somasundaram Viswanathan B Sakshi Umariya Krishna Prasad Mahato and 53 More
Tech Mahindra
This helped. should be added to the pega help.
Barclays
Excellent description. Thanks
SHI XUEBIN
Capgemini
Waw...great explanation Eddie.
Capgemini
FR
Your comment has been very helpful for me.
Thank you very much.
Definitely helps, thx!
Capgemini
Thank you for the explanation
sowmya Amrutham
TCS
Wow eddie. This is an amazing explanation.
ACCENTURE
Properties with prefix py, Ex: pyLabel,pyID etc
py: No relation to Pega internal usage
You can use those for Read/Write.
Properties with prefix py, Ex: pxCreateDatetime, pxRequestorID etc
px: Pega will use this for some internal purpose like when work object createdtime, Requesetor Info etc.
Even though we have write access on these but just make sure before you update these properties.
Properties with prefix py, Ex: pzInskey etc
pz: Pega will use this for identifying its own objects, usually its unique values in each table.
Don't have write permission on these properties. Read only purpose
Anbbarasu A P Subhendu Dash Nandini Gupta
Cognizant
Hi
I have a requirement. The Take Action values (the flow action description) size needs to be changed. When i checked it referred to pzActionLabelDisplay property. The display of the the value of this property needs to be changed. How can this be achieved.
Thank you
Create a new Property of you own design (like MyActionLabelDisplay) and replace the reference to pzActionLabelDisplay to use the new Property instead.
Henry
Self-Study Support
Pega Academy
Cognizant
Hi
Sorry, the pzActionLabelDisplay is a control format which displays the Take Action/ FlowAction name. The value (font size) that displays need to be changed. If i change the format to formatted text, the value does not appear itself. So what has to be done.
Thank you
HARINI S
Rabobank Group
Thanks Eddie, awesome!
Excellus Health Plan Inc
Thanks, this explains the differences in a way which is easy to understand.
