Last activity: 13 Oct 2022 7:07 EDT
Robotics Tip of the day: Press Control when loading a project to prevent project items from opening
Tip #15: Open a project faster by holding down the Control key to prevent designers from being opened.
Your project, by default, remembers the designers that you had open when you closed the project. Prior to loading each designer, the system checks to see if the Control key is depressed and, if so, it does not load anymore designers. Notice the message in the example below:
Note: Click here to see the latest Tip of the Day and a list of all prior tips.
