Robotics Tip of the day: Find usages of objects or automations (Where did Navigator go?)
Tip #17: The Navigate To feature found in prior versions is now Find usages. Select Find usages from the context menu on the Palette or by right-clicking a block. A dialog appears that lists each block that references the control you selected. This dialog stays open until you close it. You can have more than one dialog open at a time.
To filter the dialog to a specific property, method, or event for the selected control, click the arrow next to the control name, and select the property, method, or event to filter by. Clicking Show all returns the unfiltered list. To go to a specific block, select a property, method, or event and then click Find to highlight the block.
Note: Click here to see the latest Tip of the Day and a list of all prior tips.
