Repeating grid and Prompt Select Issue
Using pega 6.2 sp 2
I know this has been addressed before, however i have not seen a solution that works for my scenario.
I have a Prompt select property in a repeating grid. I want the user to be able to select from the list for each row in the repeating grid. The property is ALWAYS editable. The section Edit Mode is READ/WRITE. The user selects an Icon from the harness (Perform) which calls a Local Action (Flow Action). The local action displays the section in Modal Dialog. I see the PromptSelect property displayed, but it is NOT editable. When i switch the property to a plain text property, it is editable. I've tried several different property types, the Radio button did NOT work either.
Is there a solution to this issue? Was there a hotfix for this?
