UHG
Last activity: 11 Oct 2015 21:40 EDT
Pega 7 personal edition on windows 10
Does Pega 7 personal edition installed on Windows 8 works fine if the system is upgraded to windows 10. Please let me know if it needs to install again pega PE 7.1.6/7.1.8 when OS is upgraded to windows 10 from windows 8 or separate PE package will be released for windows 10 OS? please let me know if anyone has any updates regarding this ..Thank you in advance..
SG
Well, it's hard to answer your question because Windows 10 is not going to be available until July 29 this year (http://goo.gl/9vPhUD).
If you are concerned about having to install Pega 7 PE again, you can try to install it into a Virtual Machine so it will be portable across all OSes. This website allows you to download a VM for Windows with a flavour of IE: http://dev.modern.ie/tools/vms, and you can use either the free VirtualBox from Oracle or VMware Player to run the VM.
I have Pega 7.1.7 PE running in a Windows 10 Enterprise Tech Preview; Build 10130 virtual machine (VMWare Fusion for OS X). In fact, I've had it running on Windows 10 when the first preview build came out.
Pega will make an announcement when the PE is officially available for Windows 10.
eddie
Updated: 16 Jun 2016 9:46 EDT
TBC
Is there any news/update on running Pega 7 on Windows 10.
I need it to support pega 7.1.7 or 7.1.8 including Excel plugins with Office 2013 (I assume 32-bit still).
Please let me know.
Thanks.
A
Infosys Limited
I had issues in running Exercise System (7.1.6) on Windows 10. I was getting memory overflow error. Actually it turned out to be an issue with the older version of VMware player. I installed VMware -12 and it's working fine now.
TBC
It actually seems to work better in Win 10 than in Win 8.1. (Pega 7.1.8)
I think Microsoft have worked hard to make W10 backwards compatible. It include the latest IE11 as well as Edge.
Ernst & Young LLP
I
SG
You may want to try downloading the latest VMware Workstation Player from https://my.vmware.com/web/vmware/free#desktop_end_user_computing/vmware_workstation_player/12_0.
